If your camera is working it might be best not to try updating it. It is very likely it is already fully updated as the latest firmware was released in 2016 or 2017. With the aircraft and camera on and bound to the ST16 from the main screen go into System Settings, About controller, and post a screenshot that shows the firmware versions.hello how to update the cg04 camera some sd card does not work thank you
Bonjour voici une photo merciIf your camera is working it might be best not to try updating it. It is very likely it is already fully updated as the latest firmware was released in 2016 or 2017. With the aircraft and camera on and bound to the ST16 from the main screen go into System Settings, About controller, and post a screenshot that shows the firmware versions.
BonjourYou have the latest firmware on the ST16, but the camera is not bound to the ST16 (no WiFi link). In the other thread you stated the camera and aircraft were working so you need to have them powered on and binded to display the firmware versions for autopilot (aircraft), camera, and gimbal. There is no RealSense for the H920+.
I know 16GB and 32GB SD cards formatted as FAT32 will work in the CGO4 and need the U3 rating to be able to record in 4K. I think it will also work with 64GB and 128GB SD cards formatted as exFAT (formatting them as FAT32 reduces their usable capacity to 32GB).
Oui bien sûr sinon j’aurais pas pu prendre de photos et vidéosDid you have the aircraft and camera on when you went to the About Controller screen in the System Settings?
