ST 16 woes
I am having some display with my ST 16 s. I have three of them and all three don't do what I would like. So if anyST 16 gurus would liketo step up, I would love the advice. Issue 1, the time that shows on the flightscreen and on all the data files is one hour off. I have gone into settings and reset the time but when I go back to the flying screen it goes back one hour. I have tried thr Auto feature, changing time zones, and everything else but it goes right back on hour. Issue 2, there are a couple of places on the various screens where I should be able to have my name listed. On the flight screen at the very top in red letters it says "Welcome, pilot". That should be your name. Also a couple pages in the settings it should have your name. I have gone into settings and put my name in as "Owner" but that changes nothing. I'll leave it there for now. If I can get these two items fixed, then I'll move onto other things. Thank in advance for the help.
The time will be taken from GPS. In this case the ST16 FW does not handle the summer time corrcetly. If you get time from WiFi then it is good. Currently I don't know how to avoid that GPS overwrites the system time.
There no such feature to enter your name. The owner is a relict from Android and has no influence on the flight mode app.
Edit:
What you can change is the model name. If you create a new model you can give it any name you want. The model name is then in the upper left corner of the home screen from the flight mode app.
Tonymus
