I touched the st16 icon on the top right corner of the screen and now I can get anything, it is blank/black
When you say touched, can you explain in better detail, what mode were you in on the screen or ????I touched the st16 icon on the top right corner of the screen and now I can get anything, it is blank/black
sorry should just be ST16on the touch screen pad I touch the white icon that is st16p. I has started it up
I'm sorry I can't readily help you, white icon, do you know which one? I don't see anything that would cause your screen to go black? Try this, take your monitor battery and disconnect it for about a minute, reinstall, maybe it was a glitch. If that doesn't work someone else will have to chime in.on the touch screen pad I touch the white icon that is st16p. I has started it up
