- Joined
- Aug 30, 2019
- Messages
- 4
- Reaction score
- 1
- Age
- 36
Tried 3 different USP thumb drives that used to work with it, now it does not read them and can't transfer data. Also directly connecting to a pc doesnt work. Any suggestions?
It sounds like a problem with the USB port. Does it charge properly?Tried 3 different USP thumb drives that used to work with it, now it does not read them and can't transfer data. Also directly connecting to a pc doesnt work. Any suggestions?
Yes it charges, but dos not read thumb drives neither and that port is a different USB port. Do you just plug the charger USB cable to PC and done? Connected? Never worked for me, tried 3 different PCs, windows 7 and 10.It sounds like a problem with the USB port. Does it charge properly?
I use the charging cable to connect the ST16s to the PC. I've never used the USB on top of the controller.Yes it charges, but dos not read thumb drives neither and that port is a different USB port. Do you just plug the charger USB cable to PC and done? Connected? Never worked for me, tried 3 different PCs, windows 7 and 10.
PC does not recognize the USB charging port connection. It does not even say any USB device has connected either needs a driver or not, nothing.I use the charging cable to connect the ST16s to the PC. I've never used the USB on top of the controller.
You must use the Yuneec charging cable. It allows data & charging. A standard phone charging cable will not transfer data.PC does not recognize the USB charging port connection. It does not even say any USB device has connected either needs a driver or not, nothing.
I am using that cable which came with the remote.You must use the Yuneec charging cable. It allows data & charging. A standard phone charging cable will not transfer data.
