Yeah that would really be bad.And who knows what will happen if you pickup a virus from the internet?
Are the screen caps stored in the same SD folder as the photos? I have tried this many times, and do not see the screencaps. Thank you for helping.Yes! Hold your finger on (what looks like) the "Page icon" in the center between the +&- volume, and the "Home" icons. In about 2 seconds it will record a shot. You can find it in the gallery.
This works in both tablet mode and in flight control mode. I often use it to record my rate setting changes.
The screenshots are stored in the Gallery of the ST16, they are not stored on the SD card, no card is necessary. Tap the [Pad] button and clear the warning, tap the Apps Icon, tap the Gallery Icon, and you will find them in the "Screenshot" Folder.Are the screen caps stored in the same SD folder as the photos? I have tried this many times, and do not see the screencaps. Thank you for helping.
YES! Yes they can! You can either use the File manager in the Tablet to copy them to the SD card. Or plug the powered-up ST16 into a computer USB port and use the computer file manager to locate and process them.Can these be transferred to the SD card or downloaded?
There is no Screenshot folder in my ST16 Gallery folder...?The screenshots are stored in the Gallery of the ST16, they are not stored on the SD card, no card is necessary. Tap the [Pad] button and clear the warning, tap the Apps Icon, tap the Gallery Icon, and you will find them in the "Screenshot" Folder.
