Can someone explain to me how the controller and copter decide which transmitting mode will use?
I'm analyzing the transceiver section of both controller and drone and first I want to say that the SWR of stick ST16 antenna in all 2.4G band is no lower than 2. This will be repaired soon. Also soon will check how is the SWR in the 5.8G antenna, but probably will be the same.
Good antennas and switch both points to FCC mode gives me some good expectations.
