ST24 b95 firmware release notes and update procedure
What new features does the b95 firmware version contain that are not in the b94 version? I understand that obtaining release notes from Yuneec would be like waiting for the Santa Claus.
What is the procedure to update the ST24 firmware using the SD card slot? Also what are the required specs for the SD card e.g. class 10, u3, max GB capacity, etc.
I would appreciate any help.
I have to use some gut instinct with this. That date is not far off the 920 recall date where 920 owners sent their rigs in for a “critical update” only to have them returned after being castrated and converted to a 920+.
Without having a detailed “readme” file for the contents of b95 I fear the “update” could remove functionality of the -24, limiting unconverted 920’s to function in the same manner as the 920+.
Stay with what you know works, and if it does not appear broken, don’t fix it.
As for the SD card questions, use what you know works best in the 920+ as the cameras establish minimum requirements as they provide what is written to the cards.
Bech
