- Joined
- Jun 14, 2018
- Messages
- 225
- Reaction score
- 61
about a week ago I had a crash while landing with gps off . Broke four props and gimble mount . Repaired it the other day , performed a gimble calibration an accelerometer calibration . Was too not and windy to fly so I did not test the aircraft .
Well today it cooled off enough this evening and no wind so I venture out on the back forty to discharge my batteries so I could put a storage charge on them .
I performed a compass calibration and let the bird sit until it hag satellites and the started the motors and let it idle for a few mins . For a bit it seem okay but was a little slow in coming back down . I flew around for a short bit and checked that that I was in angle mode . Went up about 30 feet and the bird refused to come back down . It was also making a noise like it was fighting me to go lower . I then remember the trick about pushing the start stop button for a few seconds and was able to land safely using that trick . It took a while but it landed . Battery voltage at landing was at 15.8 .
To be safe I turned the aircraft off and moved back to the same spot I started and performed a compass calibration again . Took off with the same battery and it seemed to respond well. Went up a little and made a few landing and taking off again with out shutting the motors down.
Flew around a while longer to the 14.5 volt mark and the landed and changed battery. Made two more full flights on two batteries down to 14.5 volts with a couple of landings .
I did notice when on the first flight I had managed to land by pressing the start stop button that once on the ground I got a gps error.
Wonder if the aircraft defaulted to return to home for some reason and just hovered where it was. I was close to it but in angle mode and obstacle advoidance was off
