- Joined
- Jan 21, 2019
- Messages
- 1,096
- Reaction score
- 660
I've had my TH Plus for 6 months and 16 days, with a lots of stick time both work and personal. The first thing that one will notice, specially when someone flies other craft or a seasoned RC pilot is the lack of center curve or manual retention adjustment for the TH Plus (I cannot vouch for other Yuneec products)
For a while now, and I thought I had shared his in passing, but did not. Here's how, I worked around the problem.
I purchased a Yaw (and also bought another for the Pitch) resistance, made for the H480, but with a small mod. it's doable. 3D Printed Remote Controller Yaw Resistance Controller for YUNEEC Typhoon H480
2) Remove the x4 studs with pliers.
3) Add 3M thin double sided tape on for corners that would adhere to the plate.
Final result: I am very satisfied with this simple mod. and it has enabled me to get that smooth pan shots. (Now, I just have to find a solution to the gimbal dial control)
- I shorted the sticks to 10.46mm
- Inserted a rubber tube (found the tube in my toolbox, remnants from my RC Heli. gas days)
