The owner’s manual information about the transfer of image data seems very limited. Can someone help me to find good information on this topic? Also explain the statements below from the manual.
WARNING: After inserting the Micro SD card in the computer, be sure to safely eject the SD card properly so it does not corrupt the card. If you directly pull out the Micro SD card from the computer and plug it into the aircraft, the aircraft with this Micro SD card won’t support the digital video downlink, and the photo taking and video recording function can not be performed.
Does this mean that once you pull out the micro SD card and insert it into a computer and then attempt to reinsert it back into the drone it’s done for ? ( I think my Sandisk card is now useless! ) Should I plug the drone USB port directly to the computer and download images that way? Any help would be appreciated!
