Trying to get my Typhoon H airborne
hi im trying to fly my typhoon h for the first time i can get the propellers moving but i cant seem to get it off the ground. i also need to find the firmware i can download so its up to date if anyone can help that would be great. also when i got the T H on it blinks blue repetedly
Welcome to Yuneec Pilots!
It is most likely that your TH has the most recent firmware which was released in March of 2017. To verify you need to have the camera mounted and the aircraft and camera bound to the ST16 controller. Go to the System Settings page and select About Controller. Compare your versions to this photo.
If the Status LED under the battery keeps blinking blue rapidly then the aircraft is not bound to the ST16 controller. If it's blinking purple slowly, it is bound.
You can bind by following this video.
You can also download the attached manual that has been enhanced by users.
So I'm having a problem with the updated firmware I need to update it but I also got a problem trying to bind the camera Its wanting me to enter a password? I'm not sure why the password could be
The controller is definitely showing an older firmware, but do not update any of them until you get the aircraft and the camera bound to the controller. You will need that to be able to do a proper firmware update of the system.
Reactions: 7cyclops
Yuneec skins has the latest firmware
lbmsolution
