Hi, those of you that shot vids or stills for real estate purpose. Do you set "S2 up" and lock the cam fwd and then turn the H or do you usually use the cam pan function?
Generally speaking, using the pan control is both less effort and produces better, smoother, more consistent results, simply because it is quite hard to achieve a manual turn that consistently.
