Two cameras
The Netherlands
I am about to change lenses on my 2nd CGO3+ but was wondering about the camera firmware. It would probably be a good move to (attempt to) install/ reinstall the camera firmware to be sure both are up-to-date.
Is it possible to do this without repeating the whole update procedure?
Install each camera on the aircraft and check the firmware versions in Settings. Bind each camera after putting them on the H. If the versions are all the same there’s no need to do firmware again. If they are not the same just do a firmware update for the camera that’s different in the traditional manner.
rubikonsgd
