Typhoon H and GUI - Connects but no data, can't test
New Typhoon H owner. I d/l GUI from the Yuneec site and installed it on a pc running windows 10.
I start the program then plug it into the powered off Typhoon
Pretty quickly the Typhoon powers up, light blinks blue fast
If I go to Device info it just says Typhoon H, nothing else
GPS info shows me 7 satellites
I tried changing the Geo Fence settings but it doesn't change
I go into sensor info and it's as tho nothing is connected, everything reads all 0's and I
can't enable testing to test the motors.
I figure it has to be connecting since it powers up the Typhoon and it does tell me it's a Typhoon
in device info.
Oh, I tried connecting using USB and Serial (both using micro usb cable)
Kept crashing at 1st when I tried to select Connect USB but then tried it in admin mode and it worked - well, it didn't crash, I'm still not getting any sensor info
any suggestions on what I'm messing up
thanks
You need to have the H powered on before connecting the USB cable to the PC.
To open the GUI, right click on the icon and select "Run as Administrator".
I tried it that way with no luck. I'm thinking maybe I need to try a different cable - not home right now but will try different one when I get home.
I appreciate the response - I tried it turning the H on after opening the GUI as Admin after I posted the above
Windows 10 is really a pain with the GUI. I've had to connect numerous times to get it to work and then it freezes after several minutes. But the H must be on and booted before connecting the USB to the computer. Also, you may need to use the link in the GUI to download the driver.
oliver555
