Typhoon H Camera Firmware
Just picked up a Typhoon H and all firmware is current EXCEPT for the camera:
AutoPilot: V1.35
Gimbal V1.25
Camera V3.2.26(A) C-G03-Pro
RealSense V1.10
(AFAIK Mod edit) As far as I know, the camera should be V3.2.34(A). Is there a way to just update the camera, or should I load TyphoonH_Ver3.04_A.bin and it will update the camera firmware?
AutoPilot: V1.35
Gimbal V1.25
RealSense V1.10
AFAIK the camera should be V3.2.34(A). Is there a way to just update the camera, or should I load TyphoonH_Ver3.04_A.bin and it will update the camera firmware?
Hi K9BM,
both ways are possible :
I you already have the latest firmware version, applying it will only change what is needed to be changed meaning if the other versions are already up to date, they won't be modified.
Thanks to @WTFDproject, you can also refer to here for procedure to only replace camera firmware.
Failed firmware upgrade - failed to initialize camera
Yes, that is the latest firmware. Nothing new since 2017.
bcecleaning
