The following information is the Channel Output information you should see with the Rate slider at full rabbit in parentheses and at full turtle in square brackets. Buttons are when activated, sticks are left center then right or down center and then up, sliders are down then up, switches are up middle and down, and knobs are left middle then right.
Ch.1) Throttle - B1 (-25%) J1 (0%, 50%, 100%) [20%, 50%, 80%]
Ch.2) Aileron - J4 (100%, 0%, -100%) [60%, 0%, -60%]
Ch.3) Elevator - J3 (-100%, 0%, 100%) [-60%, 0%, 60%]
Ch.4) Rudder - J2 (80%, 0%, -80%) [48%, 0%, -48%]
Ch.5) Mode Sw. - S4 (100%, 0%, -100%)
Ch.6) RTH - S4 (0%, 0%, 150%)
Ch.7) Tilt Sld. - K2 (100%, 0%, -100%)
Ch.8) Pan Kb. - K1 (100%, 0%, -100%)
Ch.9) Tilt Mode - S1 (10%, 10%, 100%)
Ch.10) Pan Mode - S2 (-100%, -40%, 100%)
Ch.11) Gear Sw. - S5 (-100%, 100%)
Ch.12) Aux Btn - B2 (-100%)
Note that the Mode switch S4 is the only thing that affects more than one channel. If any others do you have mixed channels and it is not safe to fly the aircraft.
