Typhoon H Motor Noise
What kind of preventative maintenance should the Q500 motors get?
I have a Typhoon H hexacopter, and when I try to take off, I get a motor error and there’s a loud rattling sound, like something is lodged in one of the motors. If I take the propellers off and power up, the noise continues, so I put an ear up to each motor and try to determine where it’s coming from. I thought I had it isolated, so I dismantled the end of the arm to get at the motor. I found nothing and put it all back together and the noise and motor error doesn’t go away.
The drone doesn’t shut down any of the motors— if it did, I’d know which motor to repair or replace.
My first thought was that some metallic foreign object got into one of the motors and was rattling around. You might think that it would be easy to figure out which motor is causing the problem, but the rattling seems to be coming from all directions at once. I cup my hands around each motor and put an ear up to it, and the noise comes from all the motors at once. Sometimes I think I’ve found it, only to have the noise coming from one of the other motors a few minutes later. The noise definitely isn’t coming from the motor I took apart last night.
Any ideas, suggestions??
Greatly appreciated-
Thanks- Douc
Hi—
I didn’t know it was possible to run the motors one at a time. How do I do that?
Hi.
On the main page of the GUI (sensor information) in the upper right corner there's the motor testing. See pic
You have to enable testing, you get a message for removing propellers, after your confirmation you can "click" with the cursor on each single motor to make it spinning.
Dwonlo
... How do I do that?
1.) Download and install the Typhoon H GUI from the Yuneec Skins repository:
2.) After the GUI is installed, adjust the desktop Icon properties to run in compatibility mode for Windows 7 and to run as "Administrator".
3.) Start the GUI (It may appear unresponsive for about a minute on some machines. Allow time.)
5.) Follow the instructions on the GUI first page to Connect the Typhoon H to the PC. The USB must be a DATA CAPABLE USB cord. Ordinary USB charging cords will not work. Note your PC almost certainly already has the USB driver mentioned in GUI Step 1.
6.) Select the "Sensor Information" near the upper left corner of the GUI screen.
7.) Click the "Enable Testing" check box in the "Speed Controller and Testing" section at the upper right of the GUI Screen.
8.) Ensure all propellers are removed, and click the box in the confirmation pop-up.
9.) Use the mouse to press one motor circle at a time for individual motors, or press "ALL TURN" to start all six.
Hi again—
Thanks so much for this. I don’t use Windows— I’ve been using only iMac iOS and Safari on my iPhone and iPad. Is there a Mac compatible version of this?
Dwonlo
Hi—
Getting my drones ready for the upcoming season.
On a windows computer, the gui files won’t download or run. The errors are unsupported file type, or it says the files are infected with a virus 🦠, unsafe to run.
Here is the link to the most recent version on the Yuneec Skins site (working fine for me).
Or you can download from our new repository on OneDrive here:
This is a valid link directly to the download of the GUI.
I just tried to download the GUI from Yuneec. It won’t load. It causes network errors, and is identified as having a virus. It sometimes also says invalid file format. It’s an exe file, and I’m running Windows 10 on a laptop. Exe files should run.
From where did you download the file?
Run the file as Administrator. When the warning screen comes up select more information then tell it to let the file run. I have been running this program for 6+ years without a problem.
The above is valid provided you downloaded this from the YuneecSkins website or the OneDrive link provided earlier. I cannot vouch for any file you downloaded from anywhere else.
The message you get when trying to run the file is typical for an .exe file that has not passed Microsoft Security scrutiny. This is a typical situation with support files like this.
Programs provided by @h-elsner for use with our Yuneec products get the same type of warning the first time you attempt to run them, but they are completely safe.
I tried Yuneec.com, but it isn’t there. I used the links given in this thread, and it takes me to a page with all the downloads for every Yuneec product, so I get to the right page. There’s no option to open the GUI, but the tab shown as download all files that pertain to this product. The GUI is listed there, I double click on it and that’s when the errors start. I’ve gotten unsupported file format, a download window that crashes or hangs, or a virus alert message that doesn’t allow it to continue. One link says an iOS version exists, but there’s no download tab.
My subscription to Dropbox has expired ages ago, but there’s no direct download link. Every link on the page opens Dropbox. I’ve tried to update my subscription, but it crashes.
I just tried both links and both downloaded easily on a Windows 10 desktop running Firefox browser.
What is your operating system and what browser do you use?
Have you checked your security settings to ensure they are not set too high for normal downloads?
There is no iOS version, only for MacOS. The Windows version is not working with Windows on ARM processors.
Edit: Also no MacOS version (that exists only for the old Q500 GUI which is not usable for Typhoon H).
Reactions: DoomMeister
You do not need a Dropbox account to download the file. View it in your browser when the option shows as you access the link. The site is not yuneec.com it is yuneecskins.com, and if you are going to yuneec.com there is no telling what you are encountering as Yuneec only deals with pro level drones and only through dealers.
What make and model is the Win10 laptop you are using? Are the “virus” alerts through some 3rd party antivirus like McAfee or Norton?
I realize that Windows is a different OS compared to MacOS, but I have used both and find them both useful in their own rights. The GUI was not developed for MAC because of the constant insistence by Apple to jump through hoops each year to keep it on the App Store.
cubespace11
