Hi Guys I have had problems accessing the hidden menu (ie compass/giro/accelerometer)
I found that the magnification gestures in settings was turned on, if it is you wont be able to get into the hidden menu.
to turn off. 1) exit the app, 2)go to settings, 3)select accessibility, 4)turn off magnification gestures
then you will find the hidden menu !!!!!
if no4 is on you will not access the menu
