Typhoon H Pro
Hi, I bought a typhoon H pro and make the update an all, when i went to fly it the motors start but it wont take off.
You don't need to post the same thing in 3 different places !!!
1. What flight mode are you in ?
2. What are the lights on the back of the craft telling you ?
3. What is the Rates control set to ? (should be 'Rabbit Mode')
4. What, precisely, do you mean by 'can't fly' ? Do you mean it won't lift off when you raise the throttle, or do you get any warning messages, or are you prevented in some other way ?
The more detail you can give us the better.
In angle mode, the lights in the back are purple and white, it was in turtle mode, I start the motors had 16 sat but when i raise the throttle stick it doesnt do anything its stays in idle and no sign of change in anything, no warning messages or anything else.
OK, set that rates slider to Rabbit for launch, and see if that makes a difference. I bet it's that.
If not, next thing to check is that your throttle control is outputting properly in the Hardware monitor on the ST-16.
Im in Puerto Rico, i did the update again of the st16 and the H put it in rabbit mode and now its working. thank you for your help.
thuocdaday
