Typhoon H startup problem.
Hi,
I have a problem with Typhoon H, flashing red and blue alternately. the camera view is correct, the gimbal is working. after compass calibration and rebooting, it repeats the message about the necessary calibration.
The controller says that it is ready, but it does not want to turn on the engines.
There are videos of the drone's behavior in the link.
IMG_2653(2).jpg and 6 more files
Will you help?
The slow red flash in both videos tells you that initialization has failed. The red/blue flashing is that the aircraft is not bound to the controller (blue) and failed initialization. The orange/red flashing is that the aircraft is in bind mode (orange) and failed initialization. I suspect the failed initialization is that the controller is set with RealSense enabled and it is not installed or is not functioning.
You should take the time to read through the attached manual, and familiarize yourself with all of the functions of the system.
  • TYPHOON H USER MANUAL Vcho3-2.pdf
DHYradio
