TyphoonH GUI program
Hi. I have a question, is there any working version of TyphoonH GUI program? On win 7 it does not turn on at all and on win 10 it turns on but after a while it closes itself. The yuneec website now has nothing to download after the change.
The behavior is sometimes seen if the GUI is not set up to "Run as Administrator". You can check the result by temporarily selecting "Run as Administrator" as follows:
1.) Right Click on the GUI Icon
2.) Select "Run as Administrator":
If it works, you can permanently select "Run as Administrator" from the "Properties" tab at the bottom of the same menu.
also try disabling the WI-FI on the PC, I have the same problem with the WI-FI active.WI-FI off, works great
Reactions: Pier2162
vivareflex
