UAV Pilot flight simulator with the Wizard BLH8645
I bound my BLH8645 Wizard to the UVA sim to practice.... a learning course after reading the manual . the remote has the 4 way rocker ( up down left right ) BUT when you tilt above 50 degrees it controls elevator ( left joy ) & level it does forward / back ( right joy ) Glad to get some practice BEFORE out in the real world & learning & CRASHING !!! https://www.horizonhobby.com/pdf/BLH8645-Manual-EN.pdf
Thanks for the tip! My Wizard had never been used because I didn't want to risk a crash. Received my UAV Pilot dongle today and was able to bind to the Wizard and practice using it. Now I'm looking forward to giving my H with RealSense a go in follow me mode using the Wizard as a beacon. Thanks again!
RG
The ONLY negitive is ONLY 1 controller will bind at a time ! you will need to run thru the procedure each time you switch controllers
rubikonsgd
