unable to land - turned off motor?
Hello all,
I just did a back yard flight to empty a battery, flew in angle mode at 3 meters max altitude and when it was time to land the Typhoon H with (RealSense) would not let me.
push the stick down and nothing, I could go up, left, right but not down.. OBS was off.
Had to turn off the motor and I had damage on 3 - H Arm Latch that broke on landing.... lucky me i guess...
Anyone had this before?
I never experienced this.
rdonson
Premium Pilot
Davidson, NC USA
Did you try tapping the Red kill button until it got low enough to hold the Red button and it shut off?
Eagle's Eye Video
Global Village Idiot
Staff member
Premium Pilot
Albuquerque NM
Hello all,
See this thread...
My H will not descend! How do I get it to land?
as well as this post...
Landing Difficulties / Options
Ocoee, Florida
Can you send over the Telemetry files and we'll take a look?
I have the UAV toolbox installed and I have the Telemetry in .cvs format.
I did tried to do the red kill button but maybe I didn't do it right and panic a bit new flier do that ..
h-elsner
Premium Pilot
Bavaria / Germany
RemoteGPS, Remote belongs to FlightLog too. GPS was bad all the time. There is a drop in altitude down to -4m. What is that? A hole?
You should not fly between building. And if so, climb far above it to get GPS accuracy and be prepared for difficult landing or land in open area.
I guess Remote GPS was in inacceptabe state.
Muskegon, MI
Not sure if your gear was down or not but the manual states -
NOTICE: If the landing gear is not lowered down in Smart and Angle modes during landing, the aircraft can't descent less than 6.6 feet (2 meters) from the ground.
I have not tested what happens if you you are less than 6 feet and raise the gear and attempt to descend. Also be aware of the inaccuracy of the altimeter regarding what telemetry says your altitude is and what your altitude actually is.
Thanks all for your replies.
Landing gear was down all the time. When I do these kind of flight landing gear is always down.
I saw on the log the - 4m in alt, I didn't flight in a hole no. I got puzzle by this too, but I'm not an expert.
PatR
Premium Pilot
N. California
The gear position requirement is only applicable to models equipped with activated Real Sense.
My Typhoon has a Real Sense installed.
by the way can a Typhoon fly without the arm locked?
Ocoee, Florida
I don't think you want to try that.
When Idle or descending, what's going to keep the weight of the arm motor up. Gravity here is your enemy.
Thanks, that make sense otherwise why would we need to latch the arm.
I ordered 6 Arm Latch from Vertigo Drones, need to wait for arrival now. 1 ship to the US then to Brazil.
Reactions: AH-1G
Is it possible to test the up and down landing gears when the H is not in the air?
When I will get the drone fixed with the new Arm Latch, I will surely practice emergency landing and catch the drone in the air.
PatR
Premium Pilot
N. California
Yes it can. As the thrust vector of the propeller is in the vertical plane relative to the body of the aircraft, failure to lock the boom in place would not have a significant impact on safety during the period the motor on the unlocked boom was subjected to climb power settings.
However, during periods where power settings were reduced for the purposes of descent or hover it would be possible for the unlocked boom to sag relative to the position of the locked booms, which could/would induce significant instability problems.
So the answer to your question is multifaceted; yes it could fly but it would not be a safe way to do so.
Just for general info applicable to anyone reading this thread, performing a preflight inspection and assuring an aircraft is safe to fly is 100% the responsibility of the pilot in command. Any failure in assuring the aircraft is correctly set up and safe to fly is 100% the fault of the PIC, whether they understood how to set up the aircraft or not.
New Threads
urSco
