GPS is on the screen shot.
WHat's with you crazy people flying in snow and cold!! Clearly the H+ has better sense than you. It simply refused to fly in the cold. Might warm the packs up as much you can and try it again.
it was after an update?I was in Angle mode and tried Sport mode as well. The batteries were kept warm. I moved a couple of times about 50' to try a different spot. After several attempts I went thru the settings and turned off and then on several of the settings including GPS. After doing so the motors finally started and it launched as normal.
I don't understand the terms in the screenshot.
"Not Arming: switch to a pilot mode first"
"Failsafe mode off"
"No valid positon. switching to manual mode"
"Failed to switch mode automatically"
I will be attempting to fly in another hour or so. Temp is warmer in the upper teens.
I
"Failed to switch mode automatically".
No, I have flown several times since I did an update.it was after an update?
That would make sense. However, it properly showed the distance as 14' on the display which would suggest it had good positions for the H and the ST16.The no valid position sounds like it could not find itself despite the number of satellites locked in. I've had this happen with other GPS gear, takes a long time to locate itself. GPS weirdness.
