This document is a compilation of MEMBER GENERATED INFORMATION. The accuracy of all information is limited to the observations and interpretations of the contributing member(s). Errors may be present. It is the responsibility of the user to evaluate the information prior to use.
The intent is to provide a resource for issues related to our hobby. If you have any guidelines, drawings or useful information, please post in this thread. You will be given credit for the information. Material covered by copyright will not generally be useable. However, links to the original information generally will be. Links to YouTube videos you found informative may be useable. Use of all links to external media must conform to Forum Guidelines.
NOTE: The WTFDproject.PDF is a collection of attachments arranged by attachment number. It contains its own menu at the front of the Document. Once you are in the PDF document, scroll down the MENU to find the Attachment you need. Click on either the Attachment Title or Attachment Number, and it will take you to the actual attachment within the same document.
NOTE: The "Table of Contents" version attached is a compilation of direct links to individual articles and may be more convenient for many. The articles in this format are grouped by subject/title rather than by Attachment number. The articles in this format are also significantly more up to date.
Date of latest "WTFDproject.PDF" revision: 03/11/2022
Date of latest "Table of Contents" revision: 03/23/2024
