WiFi viewing of E90 camera video real-time on an iPad
I was wondering if there is a way to view the E90 cameras video on an iPad via the WiFi signal. I know there are apps for the cg02 cameras.?
Yes you can connect to it via the CGO3 app.
However you cannot control it.
That is you can't change most settings.
For iPhone/iPad
CGO by Yuneec International Co.,ltd CGO on the App Store
For android
CGO3 - Android Apps on Google Play
Simply connect via WiFi to the camera on your device and run the app.
Obviously you need to be close. As you are talking to the camera not the controller.
I have wondered if you used a gateway and connected it to the camera using a large external antenna. If you could then connect to the gateway via your device and therefore get greater distance.
csandoval
