Ok guys I hope someone is able to help me with my issue that I just barely start to have. Ok so I bought a 3D printed charging adapter so I can charge the H batteries on my regular lipo charger so i can charge them faster & be able to balance charge them. But now out of nowhere I have 2 stock batteries & I successfully as usual charged one of my batteries & now when I attempt to charge my other battery my battery keeps stopping after only about 2 minutes after I start the charge which bring up a message saying battery connection problem but to be sure it wasn't my charger or the 3D printed adapter I connected the other battery & it has no issue whatsoever & I've attempted this in 3 separate modes on my charger (Fast Charge, Charge & Balance Charge) but nothing fixed my issue. Plus on top of that as I was checking my connections I Noticed that the outside plastic exoskeleton of the battery is loose from the internal block battery part of it so if you hold the entire thing in a single hand you can kind of move that internal block piece which is the battery itself, when I say that it moves a bit Im only saying that it does in a way of up & down so NO it is not moving from back to front, but I also am curious to know if that little bit of movement that it does have may be enough for it to actually have the connection that connect the physical battery block to the Yuneec proprietary charging adapter that we all are able to see from the outside. I wouldn't think that could be the issue unless the charging adapter piece is directly soldered onto the battery so there isn't any ability to provide movement of any kind so they'd either have to break connection or not move whatsoever? Does Yuneec Warranty the Batteries?? Thanks ALL Tom C
