I was flying my drone with no great issues today, then...
The drone would not lower it was sat at 5-6m so the altitude was working, occasionally it sort of dipped sounded like it was going to lower then went back to it original height.
I stayed with it for about 4 minutes with no response it hovered and maintained the height required I could not lower it at all.
I have had this problem before but on the earlier occasion I was able to get it over a shed roof and reach up and grab it.
I have checked each time I have operated the machine and it always tells me that the height is zero meters on take off. I worried the first time as I was not sure what had happened but this time I was checking and loking at everything and all data coming back was correct as far as I could see it.
I need to get the machine repaired as the damage is extensive this time. tree climbing at 52 was a childhood memory I don't want to repeat again so any thoughts...
PB
PB
