YUNEEC please listen User-Wishlist
WISH LIST for update for TYPHOON H
please post what you wish in next update of the Software ! :)
these are my wishes:
  1. - ST16 low noise Fans
  2. - Boot and binding in a minute
  3. - Notification sound when system is ready to start
  4. - Settings for RTH-height
  5. - RTH first get higher and then fly home
  6. - RTH switchable dynamic or static HomePoint (place where you have started)
  7. - Tap BatterySymbol shows loadcycles, cells... and show flight time
  8. - GPS Hold more accurate
  9. - NFZ able to disarmed for people with license
  10. - LogData-App on ST16 with export for work
  11. - Map view for finding last positions of bird or for flight control
  12. - WayPoints with MAP (in cache)
  13. - Control the speed of automatic Modes (CCC, POI etc) with Turtle Rabbit wheel
  14. - Possible to turn off front-lights or all lights
  15. - New Batterys with Level LED
  16. - Flight Boundaries control in ST16
  17. - Gains and Brakes on ST16 for Flight-Controller in advanced mode
  18. - Advanced mode more Speed (70kmh) not only in follow mode
  19. - GamepadController for make Cam-Settings (ISO/Shutter)
  20. - More CamSetting sharpness/flat for better Post Production
  21. - Gimbal-Settings Speed and adjustable Horizon-Tilt
  22. - Gimbal-Setting in TeamMode more SpeedRange of sticks, if you need
  23. - Format and delete Files on CamSD in FlightApp
  24. - FlightModeSwitch „smart" to "GPS off“
  25. - Team Mode possible to say which Controller control cam or Bird
  26. - Team Mode possible to use ST10+ for CamControl and ST16 for flights and CCC/POI
  27. - Team Mode ...switch back to ST16 from wizard by flight if the Wizard User need Help
  28. - selectable PRE-Settings for AUX-Button: Lights off, Switch to MapView, Cam look down
  29. - fix DataTransfer: Video Latency and stability for smooth stable Video
  30. - fix DataTransfer: TelemetryData in FlightApp
I place my vote for 4, 8, 11, and 12. The others aren't bad, just my priorities for the short-term. If I could have only one feature, it would be to use the ST16 in a map view and the ability to set waypoints and/or a grid pattern with the ability to trigger the camera for the proper overlap.
I would like to see
1. Swap camera pan with rate slider, that way both camera controls are at your finger tip.
2. Fix video feed latency.
3. Programmable missions like Ardupilot so it can be used for mapping and surveying.
Reactions: eric bee
Direct download the video from the typhoon H camera to the ST16, so that we do not need to keep remove the SD card from the camera for viewing and editing.
Able to direct download the new firmware from internet to the controller and update the typhoon H
Some of the UI desires sounds alot like what the DJI GO App offers, not a bad thing, not a bad thing, I think the DJI GO app is really good.
I like your list! It covers the things I'd want and more!
Reactions: Goh
If by 24 you mean to remove Smart mode, I like Smart and really wouldn't want to lose it.
3, notification sound when camera comes on-line.
Add write telemetry to SD card.
Reactions: Goh
ditto
on #24 Smart mode is ok and can be useful at times, but a way to disable the 'circle of death' maybe a disable that 26foot fly away thing with an option screen with "yes I agree" several times or something?
Reactions: Snagglesworth
Ok I'm with that, some very good and simple tweaks for the future.
All of these sound good, but a couple more points:
#5 and 6 yes. Being able to RTH where you took off would be great. But landing near the remote is still the best default. Also one other small change regarding RTH, don't put the gear down until you're ready to land. Twice now I've flown out, and just hit RTH and controlled the camera. But it puts the gear down before flying back. I know this is what all the smart modes are for, but sometimes it's just easy to flick the switch when you want the YTH back, and to keep filming.
#20 YES. And how about a log or cinestyle film mode?
Reactions: eric bee
I vote for 4,5,10,11 and battery level indicate in term of % and update manual for battery level % vs voltage
Reactions: FlushVision
You took my wishlist ;)
I hate to say this, but if this is your wish list, then you should go with Pixhawk/APM/ArduCopter and forget RTF like Yuneec or DJI. It is what it is, folks.
No that is really nonsens. Why is this not possible with a firmware. Dji can do it so yuneec Also. This wish list most Thomas are possible in the dji app
You miss the point entirely. I can get these features building my own sUAV and incorporating Pixhawk (ArduCopter) as the FC. However, this takes some knowledge of RC and a lot of effort to get it up and running to the point that it "works as advertised."
When you buy into RTF (Yuneec, DJI, etc.), you get whatever it is they deem necessary. Yes, you can hope for more and maybe you'll even get it. But to complain about what is not included (even if the complaint is totally valid) is not logical.
For me,
- THE MOST ESSENTIAL :
  • 4 - Settings for RTH-height
  • 5 - RTH first get higher and then fly home
  • 22- Team Mode ...switch back to ST16 from wizard by flight if the Wizard User need Help
- INTERESTING :
  • 1 - ST16 low noise Fans
  • 11 - WayPoints with MAP (in cache)
  • 12 - Control the speed of automatic Modes (CCC, POI etc) with Turtle Rabbit wheel
  • 17 - Advanced mode more Speed (70kmh) not only in follow mode
Reactions: eric bee
For me,
- INTERESTING :
Why do you need more speed? Surely, if you want a faster machine you shoulda bought a rcing drone, no?
Agree with 12 and 22 though.
Would like an audible tone + visible centre display when you switch flight modes as follows:
- One BEEP for Angle Mode + 2 Second Centre Screen words Display in PURPLE box.
- Three Beeps for Smart Mode + Centre Screen words Display in GREEN box.
- A continuous Beeping for RTH with scrolling words RED on display bottom.
Reactions: JohnL
I don't really need it, but if it can do, it's good for me (shooting windsurfers), that's why I just said 'interesting' not 'essential'
Reactions: eric bee
drakemerch33
