Yuneec typhoon h w/real sense camera won’t connect to ST16
Buenas tardes
Necesito ayuda con la cámara de mi dron
No consigo conectar la cámara con la emisora st16, cuando encienda la emisora y después el dron la cámara no se conecta vía wifi a la emisora, se le enciende el led de la cámara y se queda en blanco, no parpadea ni cambia de color.
No sé si es problema de configuración u otro tipo de problema
El dron funciona los mandos y arranca motores y el cardán de la cámara también funciona solo la cámara no se conecta vía wifi
Gracias
Good afternoon
I need help with my drone camera
I can't connect the camera with the st16 station, when I turn on the station and then the drone, the camera doesn't connect via wifi to the station, the camera's LED turns on and it stays white, it doesn't flicker or change color.
I don't know if it's a configuration problem or another type of problem
The drone works the controls and starts engines and the camera cardan also works only the camera does not connect via wifi
Thank you
If the indication LED on the front of the camera remains white, this means it is still in initialization and never came up. Look for me like a HW defect, most probably a defect WiFi board.
I have a CGO-ET with the same problem. Hard to find a WiFi board for that.
Buenas tardes
Gracias
I'm not sure if this was translated into English.
I agree with @h-elsner that the WiFi board is likely not functional on the CGO3+ camera.
With the camera powered on try looking for its SSID CGO3P_xxxxxx where the x’s are the last 6 digits of the camera’s MAC address using a smart phone, tablet, or PC that has 802.11a/ac WiFi capability. If present, try connecting to the camera’s AP.
Estoy de acuerdo con @h-elsner en que es probable que la placa WiFi no funcione en la cámara CGO3+.
Con la cámara encendida, intente buscar su SSID CGO3P_xxxxxx, donde las x son los últimos 6 dígitos de la dirección MAC de la cámara, utilizando un teléfono inteligente, una tableta o una PC que tenga capacidad WiFi 802.11a/ac. Si está presente, intente conectarse al punto de acceso de la cámara.
A mi me pasa EXACTAMEMTE lo mismo, solo que he sustituido la placa Wi-Fi (la conseguí en Ebay) y sigue igual. Se queda el Led de la camara en blanco fijo y no ha manera de que ninguna de las dos ST16 que tengo encuentre la cámara. Le cambie la CGO3+ por una CGO3 y si que funciona...
Posiblemente la placa que conseguí que era de ocasión esté también jodida!!!!
Very possible. But notice both comments above mention "most likely". There are several possible causes:
There is a "lens board" behind the lens.
The "Main camera board" mounted between the lens board and the WiFi board,
There are flat ribbon cables between all three main parts.
There is also a need for a power supply that may be less than fully adequate, fan control that may have failed, short circuits, and probably more things.
The big positive is that the gimbal is working. That is the hard part of the CGo3 and CGo3+ type cameras to fix. With a good gimbal, you should be able to find an entire camera assembly and change out everything inside the camera ball except the IMU (which happens to be mounted on top of the lens, but is actually part of the gimbal) if needed.
Reactions: DoomMeister
pujarawat
