- Joined
- Mar 28, 2019
- Messages
- 17
- Reaction score
- 2
- Age
- 56
You need:
One Mosfet: TPS 54328 DDAR SOP8
Two "power" Chips: MDU3603
These two are easiest. You can usually order them through online sites like eBay, Amazon or do a web search using the Id.
Three capacitors: These are 22 microfarad Tantalum SMD capacitors. Capacitor code is 226D, The needed case size is 3.5mm x 2.8mm x 2mm. The attached eBay link MAY be the right capacitors, but it does not list the case dimensions. The 226D comes in a variety of sizes, all of which look the same in the pictures. Best to contact the seller to confirm case size before purchase. I've found these
20 AVX TAJ226K020RNJ 22uF 20V tantalum capacitors 226 226D | eBay
Find many great new & used options and get the best deals for 20 AVX TAJ226K020RNJ 22uF 20V tantalum capacitors 226 226D at the best online prices at eBay! Free shipping for many products!www.ebay.com
Here's what I've found,sent the dealer a message on capacitor size? Do they look like the right parts/have the right specs etc.You need:
Hi,I've spoken to an electronics company who can do the job,just need to take it in an get quote.Shouldnt be to much of a problem.Gotta thank you again,this board and the cost was the difference between keeping the drone or not.Yes, other than the case size question you are addressing with the seller. There is a pretty fair chance that replacing these items will get the board back in service.
Do you have access to the tools needed to replace these? Or maybe a local computer repair shop that can help?
Hi,not having much luck trying to get someone to remove the 2 circuits.One guy today said could replace those parts and find something else is wrong.Looks like I might as well go with a new one.I hope all goes well, and that you get back into the air soon. I'll be here if you need me.
Tom Baumgardner
(WTFDproject)
I marked you on my map in the center of Australia at some point, because I didn't know what city. that was good enough to understand timing of replies, but knowing your city would be good. What's the nearest city?[QUOTE "I'm living in Australia
Изключително съм благодарен за тази информация!!!имате нужда от:
Един Mosfet: TPS 54328 DDAR SOP8
Два "мощни" чипа: MDU3603
Тези двете са най-лесни. Обикновено можете да ги поръчате чрез онлайн сайтове като eBay, Amazon или да направите търсене в мрежата с помощта на Id.
Три кондензатора: Това са 22 микрофарада танталови SMD кондензатори. Кодът на кондензатора е 226D, Необходимият размер на кутията е 3.5mm x 2.8mm x 2mm. Прикаченият линк към eBay МОЖЕ да е правилните кондензатори, но не изброява размерите на корпуса. 226D се предлага в различни размери, всички от които изглеждат еднакви на снимките. Най-добре е да се свържете с продавача, за да потвърдите размера на кутията преди покупка.
Translation...Изключително съм благодарен за тази информация!!!
След неправилно включване на батерията и аз имах този проблем.
Съживих полетния контролер с други методи, но след тази информация ще го върна както трябва.
Още веднъж - Благодаря ви много!!!
