I spoke with my wife, she said that will be it, she said remember summer last year when you had to ditch it in the sand school! She said with a giggle!!!Yip that will be the one, green house, shed, stables etc at my home,
Ok I will leave at patio window, I will let you know just after 10pm,,, thanksThe long storage of the aircraft may be the issue at this point. Place a fully charged battery in the aircraft and power it on. Let it sit outside if possible, or on a covered patio, or indoors as a last resort. Leave it for about four hours monitoring the battery charge every so often to ensure you don’t harm the battery. This is to start building a charge in the GPS battery. Right now it never gets a good almanac loaded so never goes to GPS Ready.
You don’t have to leave the controller on the entire time. Just power it up every 20 minutes, let it bind, and check the battery voltage. When it gets down to 14.6 volts check to see if you are getting GPS Ready, then power off and remove the battery.
If you have a second battery you can continue the process if necessary. Always let your batteries cool down before charging them again or placing them at storage voltage of 15.2 to 15.4 volts.
Most of the those that I've seen fail were exposed to excessive heat. Perhaps in the trunk of a car parked in the sun on a hot day. But I'm sure there are other factors that could cause a failure. No one has found a way to correct a failed FC to my knowledge.what goes wrong on the flight controller?
Hi, your more than welcome to my one, I'm in Scotland but could post in a letter?I saw one intersting statement that say after 4h outside the GPS came back to work:
A solution for some GPS acquisition troubles
Yesterday's test was a success Just curious.........what was the temperature outside when you did the test flight?yuneecpilots.com
I think it is worth to try before one replaces the MCU-board.
Another question: Is it possible to get one of those 'defective' MCU boards for further investigations? I'm in Europe (Germany), so I think best from Europe.
I've never had any luck with reflashing. Every one that I've fixed needed a new FC. That is an immediate fix.Has reflashing the FW to the FC ever had any good effect for the GPS Acquiring problem?
Just to be honest in front of me and helpful to the community, today I tested this solution. Sorry to say, but this is not the right solution. Let us go further...I saw one intersting statement that say after 4h outside the GPS came back to work:
Did you see the answer to your post in another thread ?I live in the United States and need to download the firmware file for the Typhoon H drone. Does it matter if I download the file from the yuneec UK webiste instead of the United States?
Hi H,I saw one intersting statement that say after 4h outside the GPS came back to work:
