400' AGL Limit ?
Washington State
So as I become familiar with my brand new Typhoon Q500 4K I'm wondering what will happen when I get to 400' AGL on a steady ascent. Will my ST12 Ground Station send me a Alert, or a vibration, what ? I have not needed to update Firmware yet, and will likely change the Altitude limit, but while living in USA, this Drone is Factory set to the 400' FAA Regulation, so what happens? YUN00001.jpg
As in it stops ascending, and just hovers?
Yes. No warnings, displays or anything else (apart from the altimeter reading of course), just you'll be pushing up on the left stick, and it won't be goin' any higher... directional control still works of course (provided you are not also at the geofence boundary!), so hover will only be the case if there is no input from right stick...
Reactions: PilotRichard
Thanks for clear reply, as these go higher my stress level follows. The vanishing point phenomena makes it seem really far away, as it's brand new to me I felt compelled to ask, thanks
gocdunn
