Adjusted Lens Results
North Carolina
Here is a shot I took late yesterday eve from western North Carolina. I recently re-adjusted the factory lens in my CGO3+ and have to say it made an improvement. Not by leaps and bounds but none the less an improvement.
Nice job adjusting, looks fine all around Forrestt !;)
Reactions: Forrestt
Is that picture untouched? If so that's pretty good.
Reactions: Forrestt
what kind of adjusting did you do to your lens?
Removed enough of the epoxy to loosen the factory lens and then re-adjusted focus. Only used my St16 monitor for getting what I hoped was proper focus and it ended up being somewhat better. At least IMO.
What did you use to focus on and how far away?
I looked at treelines along the mountains that are appx .5 mile away. I tried to balance out everything in the frame to have the same amount of sharpness. I suppose the fact I have been a photographer for 20 yrs helps a bit with knowing when focus is achieved too. ;)
NetsolWater
