h-elsner
Premium Pilot
- Joined
- Mar 23, 2016
- Messages
- 1,949
- Reaction score
- 1,642
- Location
- Bavaria / Germany
- Website
- h-elsner.mooo.com
First of all I must say, I'm not a friend of antenna modding. So many thing can go wrong. Really helpful measurement equipmet starts at some 10000 Dollars. Usually you have no chance to see if all is right or wrong, only by try and error.
You need the right antenna for the right frequency with the right impedance. If this is all OK you can hope...
The IPEX connectors (the tiny sockets on SR24 or WiFi module) are not made for many plug-out, plug-in actions. First I would check with a good magnifier glass if the tiny pins in the middle are all OK and not bent.
What quality are the used pigtail cables at the drone? What kind of antennas are the that? Do they fit 2.4GHz?
From the flight logs:
The 2.4GHz connection was lost for 1min14sec! Also WiFi connection is bad, telemetry frequency is low, gaps are too big. 400m distance should be working with stock antennas and with booster anyway.
The red pins shows the time point of the telemetry datasets. We have a long time very rare data received.
-72dBm are not bad for RSSI from 2.4GHz RC connection. There should no drop in 2.4GHz RC connection with that signal strength. -90dBm should still work but below it gets dangerous. I cannot understand why the RC connection is lost.
It was good luck that RTH was received at last!
Eighter something went completly wrong with the antenna mod or you did not direct the ST16 antenna to the drone. Antenna booster have a more narrow antenna radiation beam and direction plays a bigger role compared to stock antennas.
Compass calibration: The flight path is going straight sout but Yaw shows only 165°. I would expect something near 180°. However, RTH works perfect. You can try to correct this by performing another compass calibration starting with aiming the drone to north.
Attached the KML file. You can playback you flight and look waht happend.
