Angle flight mode incorporates GPS, barometric and other sensors to maintain stable position in flight .
Every aircraft that takes off from an airport sets it’s altimeter to the elevation of the airport it’s taking off from , then some fairly complicated math , including barometric pressure ,and tower to tower updates keep the pilot flying true.
Good luck flying without a GPS system in a rapidly changing weather environment . Before GPS satellites, pilots would just fly into the side of a mountain at night during foul weather because of an incorrect altimeter reading . Both GPS and barometer are critical to successful flight (.A squared plus B squared equals C squared ) if you fly in manual mode you are using the barometer.
