Altitude set
Hi everyone,
I have a problem with setting the maximum height. Even if I set 80 meters from the app when I get back in the settings everything goes back to the default.
Can anyone give me help?
All the other parameters also return to default ...
thanks and good flight
Are you using the official BreezeCam app from Yuneec?
Are you using the iOS or Android version of the app?
If you set them without being connected to the Breeze , they will revert to default. The camera settings cannot be set at all without being connected to the aircraft.
Reactions: RiFF RaFF
thanks, I used the app without being connected to the drone ....
regards
Axel66
