Any have issues with the up and down knob?
I connect my camera to the grip and the knov wont work. I had the drone for 3 days. Only used the camera couple of times? any suggestion?
Try cleaning the contacts on the grip with a plastic safe electrical contact cleaner.
Does the tilt work when the camera is mounted to your Q500?
Yes everything works fine, except the pitch and roll knob. I pressed mode to check and nothing. The camera is static to the middle position.
In default power up mode the pitch wheel should control the pitch angle of the camera and movement of the steady grip should not change its position.
If the Pitch Follow is activated the camera follows the pitch changes of the steady grip and the pitch wheel is disabled. A second press of the Pitch Follow button returns operation to default.
Reactions: Eagle's Eye Video
babyyodajede
