Any tips on the easiest way to install the two pins in the gimbal
Any tips on the easiest way to install the two pins in the gimbal mounting plates? Is there a special tool that could be used? I have just replaced the back plate and am having a little difficulty. Many thanks in advance...
It looks tricky, I've not had to try, but with other gimbals many people use very light cable ties, if you do this just make sure there is no load held by the ties....that they are just there to catch the camera in a crash, and don't forget to trim the loose ends away for keeping the out of the cameras fov.
Reactions: PatR
nextsi
