Arm Replacement H920 Plus
Hello all. Does anyone have instructions for replacing and arm and motor on the Typhoon H920 Plus. I've searched the forum and google but no luck.
Thanks!
Hi,
We don't have much information available for the Tornado H920 or H920+, it's not to difficult to Replace a Motor Arm, you'll need to Remove the 17- 2mm Pan Head Allen Screws from the Bottom Shell to allow removal of the Top Shell. The most difficult part is trying to squeeze your Hand in between the Top & Bottom Shells to Unplug the Motor Wires on the Broken Arm from either the Yellow Plug, or the Bullet Connectors on the ESC Board, as the used either way of Connecting the Motor on both the H920 & H920+.
Thanks very much. One hinge has broken loose where you raise and lower and raise one of the six arms. Right now, it's fine. I can raise the arm and tighten. Drone flies great. But I know at some point the other side of the hinge will break. Starting to prepare.
Reactions: Yuneec Skins
Patynowy
