I've seen the threads here dealing with making your own custom connection so you can charge the Breeze battery with a standard LiPo charger. I'd like to do the same so I can use a parallel charging board. However, I'd rather use the same connector as the battery.
Is this a proprietary connector, or does anyone know what this connector's designation is? Making some adapter cables with the actual connector would be far better than using pins from a USB socket, etc.
