Battery tester
Saying not available in this link
Hi sorry for the late response but here is the uk version of Amazon hopefully it says that its aavailable.
PinBoTronix Digital Battery Capacity Voltage Checker Controller Tester with LCD for LiPo Life, Li-ion NiMH Battery Amazon.co.uk
You should make certain the meter can test internal resistance. The IR is the most important check of the battery condition.
The instructions that come with these meters are not very good. The video below shows how to test IR.
This video was using an H battery but the Q500 is the same procedure. You can just use the balancing lead that came with the battery so no adapter is needed.
nvjfirut
