binding H+
See page 53 in the attached manual.
  • Typhoon_H_Plus_Manualv0.8.pdf
Reactions: Dale w
i have tried this it seems to connect but no info battery power or any other signals form H+? i also dont have any flight records showing up?
The telemetry on the controller will not be displayed unless the camera is mounted. You can still fly it, but you will not see the telemetry.
Ok..but I still should have battery signal showing from the bird? Also no flight files??
The H Plus will record the ulog files on the aircraft only. Since telemetry is sent to the ST16s, then there is no information to record.
corteizshop
