Binding ST16 To H920
Winder , Georgia
Some one recently inquired if they can bind an St16 Controller to an H920.
I have 0 experience with this particular model.
This may be a dumb question to you guys but I just do not know the answer.
I took a look in the search section and I did not come across the answer.
Can the ST16 Controller be bound to the H920?
Thank You !!
I might be wrong but I think the st16 will only connect to the 920+. The older H920 uses the older st24 transmitter?
Regards.
Mike
I dunno. But these are screenshots from the original ST16, running firmware dated February of 2017. Not sure when the H920 Plus was released.
I don't have either the H920 or H920 Plus available to confirm anything. It would be good if someone who has either of the H920 models to post what they know.
Reactions: JMichael
Thank you to all of you.
Just to help any one else that may run across this thread, yes.
I was able to bind the ST16 to an H920 (non plus)
The binding went text book.
Calibrated all endpoints, checked them in Hardware monitor.
Success!!
All motors responded with authority.
This is quite an impressive bird.
I like it.
No desire to get clipped by one of those props though.
Owee!!
Thanks Again Guys !!
Polenutrition
