Breeze Crash
Brazil
Hi guys,
I bought the drone a little while ago. I did some flights, I really enjoyed the drone. But he began to lose control. Climbing and landing without the command being given. Today I went to make a flight and out of nowhere he landed and even the Wifi connected he did not obey the commands. I went into the Wifi settings I disconnected, forgot the Wifi and reconnected the smartphone with the drone. Everything normal, I took the takeoff the drone was flying normal, I requested the recording and with little time the drone did not obey the commands. Suddenly he left uncontrolled knocked, fell and broke landing gear, damaged the helices and broken IR sensor.
What should I do?
Contact Yuneec Customer Support for your area of the world. They will give you instructions to send flight data for analysis to determine if it was a problem with the aircraft and what options you have for repair. Use the support section on the Yuneec website for contact information.
dronelover
