Breeze GPS
It's seems that the first thing I do when I get a new drone is take it apart. With the Yuneec Breeze, the bottom cover fell off on its own. Must be a better way to hold it on as well as improve the cooling while flying.
The GPS in my Breeze 4K is a u-blox MAX-M8Q. Although cheap to buy, this model of u-blox receiver is impressive which explains how I am able to acquire many GPS satellites to fly with.
Here's a link to the PDF data sheet.
http://www.components-center.com/datasheets/f5/PYD 1096.pdf
Here's a picture of the "business" side of the GPS board. Includes small backup battery. Popped the top cover off the Breeze, removed four very small Phillips head screws and flipped the GPS board on its side.
Reactions: Brent D
To improve cooling, enlarged smaller holes on the under shell and cut out a small rectangular area.
Hi,
A photo would be nice to see where you cut the holes. From a thermal point of view the breeze is always on the verge of failure. Namely the "second flight" is prone to not taking off because of not binding with the mobile.
Reactions: headroom
vbd777
