Camera gimbal works but wont move
Hello, my camera wont move, as in tilt or pan and all the connectors are fine. Should I rese it to factory settings or what should I do to try to re-boot it? It also says failure to initiate camera, but again the camera gimbal works but wont move when I use the controllers. Thanks
How did you check to make sure all the connections between the H and the camera are fine?
I un-screwed the clip on the drone to check, and then for the camera I took off the shock dampeners and un-screwed the little box that holds the 6 connector points, then I screwed it all back together.
Did you see if all the brass tabs on the mount are in the sprung up position? Those can get stuck down and even break.
ok9studio
