Camera not connecting with ST10
The camera is blinking red and green. ST10 reads RC connected- WiFi connecting. I have tried to bind camera, but it says camera not connected. Sometimes I get a series of chimes, like its playing me a little song.
everything was working fine the last time I flew, and put back in case. Thanks for any help you guys can give me.
Try re-binding the Q and the camera to the ST10+.
Turn Everything Off Bird and TX
Turn on the ST10+ but not the bird
After it initializes select Model Select at bottom right of screen
Touch and Hold the model. Menu appears. Touch DELETE.
Now turn off ST10+
Turn on the Bird. After it is on, Title Forward and Side to Side to enter Bind Mode. Light will be flashing Orange in back of Bird.
Turn on ST10+ Select Flight Settings, then Select Bind. Bind the Model and Bind the Camera
Tap Return Button at bottom of ST10+ a few times to get back to main screen. You should now see the camera come up on display.
Thank guys for your input, I reformatted my SD card, then was able to reconnect with the camera. Thanks again
Whats the best sd cards to get for the transmitter and drone
I used the 8GB micronSD card that came with my Q500+ in the transmitter. That one isn't as important because it just records data.
I like the SanDisk brand for my CGO2+ & CGO3 cameras. Class 10 is a must, and I've used the SanDisk Ultra micro 16GB & SanDisk Ultra Plus micro 32GB. You don't really need anything higher than 32GB, in my opinion.
How can you tell if they a class 10
hospitalstore123
