Camera orientation
Other than you can see what the camera sees on the screen. Not that I know of.
However if you flip the pan mode toggle all the way up it positions the gimbal back to front and center of the copter. I often do this when landing.
Reactions: Wileytrigger21
Yep, the arrow on the screen points to home, not the direction the H is facing. If you need help with that flip the gimbal switch to the up most position and the camera face the front of the aircraft, and will continue facing the front of the aircraft regardless of airframe orientation until you alter the switch position.
Reactions: Jimcreek42
TroyBoy
