Camera quality recorded / edited
Hi hope someone can shed some light on this.
If I copy the footage from camera (card) to the pc it is great!
If I edit it it comes out really poor. Is it because it is cheap editing program?
I use Cyberlink power director and AVS Video editor
It is annoying! I have the 1080p camera CGO2+
You might first try compressing using HandBrake, (free software) then bring into your video editor. I use Movavi Video Editor 12 inexpensive video editor.
I'm guessing you are not exporting the file in the correct resolution and quality.
After editing you should export it as MP4 in the same resolution and frame rate as it was recorded. For example 1080P 30fps. It should look exactly like the video you recorded.
dubiousflyer
